Hi All
I have need help how to change a schematic who is only constant current source smps for welding.
I have look some videos and hear that when use output capacitors there is a fase shift and so I need
a opamp to ivert it and outpu go to pwm chip V/feedback pin. The UC 3845 has such pin.
I have fount a schematic of a ordinary 3-60 volts 40 amp smps supply schematic who has both but this
is afcourse a very different use, I weld with it.
a resister voltage devider between smps output is used in video, then a inverter opamp (because it,s
output filter shift 180 degrees) the opamp has also a integrator on bord as error amplifier.
The UC3845 has a opamp build in who can be used so why some people use extern?
Maybe some here can make more clear how to do best make a welding mig smps inverter with constant
voltage, I do use the current feedback afcourse but then as protection agains overload.
thanks
kees
thanks
kees
