zeus_threat
Hi I am trying to build the following SMPS, half bride based on TL494 and with isolated gate drive. Its targetted for ~150W operation +-35V OP: .Please NOTE: the gate turn off transisors are 2SA733 in reality i used those bc just for drawing . I have steps on my gate drive waveforms: and i have the following waveform from a current sense transformer wired in series with my main transformer : .
The circuit is set to oscillate at 50KHz.
The gate drive transfo is an EEL16 , an AL of 810, 1:1 turns ratio giving 100 turns primary and secondary.
The main transformer is an EI-33 set for 2000G max at 50KHz and max voltage of 382V with cross ectional area of 1.3 CM SQ. It has 73 turns primary and 23 turns secondary.
This is my first SMPS its open loop and its unprotected yes but i want at least the main section to work properly before implementing the following:
Secondary recitification + common mode inductor , Voltage loop control and overcurrent shutdown.
The last attachment shows the output of the gate drive transformer secondary
Any help to solve the steps in the waveforms are welcome thanks
