Glad to hear that. I spent the evening cannibalizing a few old PC Power supplies that were taking up space in my cellar (Glad I didn't toss them out). Was this your first time building a SMPS? Did you find it difficult to accomplish? Thank you in advance.
Yes this is my first SMPS ever build, it works from first. It is difficult until i didnt get a trick for winding BDT, when you first make it all anoter will be like "anoter day in office" I write some tips for first start up:
-double check EVERYTHING from polarity of the diodes(expecialy body diodes) to polarity of capacitors.
-put 100W light bulb in series with mains
-instead of big bulk elko (elko for 310V) use 1-10uF
-plug the mains and be ready to unplug in next seccond
-it shoudnt be BOOM if all is corectly conected
-on secondary side put two diodes and capacitor at least 100u/63V on windings for 12V (for first time i reccomend use ATX trafo) and attach voltmeter seted to DC also put a bleeder resistor 2k8 2W
-To wind a CFL torus use UTP cabel and use 3 wires and make 4 turn, on one side will be begginings on other enginngs, first begin attach to upper transistor on base and ending on E of that transistor, for bottom transistor attach end of seccond turn to base and begin to E of that transistor third turn remain for voltage feedback for now let in the air not connected.
-parralel put a 100W light bulb on primary of trafo if not glow turn of the begginig of "current turn"(one turn trough CFL torus).
-If bulb is glowing, disconect from primary of trafo
-connect voltage feedback
-if you get somevoltage on seccondary side you did it right you have SMPS
-if you didnt get voltage reverse the dirrection of voltage feedback turn.
-now should works
I hope this is helpfull. If haveany problems leave a reply
All part you can use from ATX psu.
Have fun
