Hi codex653,
I'm not sure what norazmi is talking about. The whole idea of PWM is to run a square wave from the current-boost transistors to the Gate of the FETs, through a current-limiting resistor, which swings from 0 to Vcc (12-14VDC). Driving a FET's Gate with 2-4VDC will only partially turn it on (active region) and it will blow or get super hot. I've built lots of SMPSs and that's always the case using FETs as switches; 0VGS = open and 12VGS = saturated.
Maybe he means using a DMM on AC setting and getting a reading of 2-4V, but only because it's a ratio of off-to-on time giving a lower average voltage.
Anyway, you're right about the +/- 20VGS to drive the FET and the 100VDS breakdown voltage. I'm sure norazmi will explain further or he will provide additional info.
As far as the Gate resistors you were talking about, I always use 10ohm resistors. They've always worked fine, limited inrush current into the Gates of the FETs, and switched them plenty fast enough for efficient operation. I once used some 100ohm resistors for Gate drive, but once the SMPS got really hot, the FETs blew. It seems the hot FETs Gate capacitance went way up causing severe slewing and blown FETs. You can play around with the Gate resistor values for optimal performance, but I wouldn't go too high. Just my two-cents.
Are you using Sprint Layout 5 for your PCB design? If so, can you post the .Lay for the board design? I'd love to check it out! If not, then don't worry about it. Nice SMPS by the way! Thank you for making all your work public for our learning. It's much appreciated! I'm new here, so I'm still poking around learning the in-and-outs of the forum. But I have a lot of experience and hope I can help! I also have a few SMPS's I've designed and built and can post the project details for everyone's review.
