if you have 2x500W amplifier, then a 600W SMPS will do the Job.
1200W SMPS will run 1800W amplifier
Thank you microsim
but I really like to build a real 1000 or even better 1200w smps that can handle this much power for at least 1 hour ( of course with large heatsink and large fan)
I just want a replacement for IRFP460 that does not melt down internally at 1200w power for long time
You said that I have to change my mosfets to IGBTs
Whitch one of these can handle 1200w power easily and I can replace IRFP460 with it?
1- FGL60N100
2- K75T60
3- IRGP4066
4- FGL40N120
5- FGH40n60
Thank you
I change the mosfets with IGBTs and test the circuit in 1037W (6.1A @ 170V) output power for more than 20 minutes
IGBTs case temperatures : Q1=74°C & Q2=84°C
Output diodes case temperatures : 70°C
Transformer winding Temp: 100°C
Transformer Cores temperatures : 80°C
Input bridge = 65°C
**I stop the test in 20 min because of the temperature of transformer winding**
Why the difference between Q1 and Q2 temp?
I also loaded the smps with 750W (4.2A @ 178V) power for more than 1 hour
IGBTs case temperatures : Q1=64°C & Q2=72°C
Output diodes case temperatures : 59°C
Transformer winding Temp: 72°C
Transformer Cores temperatures : 60°C
Input bridge = 58°C
are other temperatures for 1037w normal???
because ludo3232 (starter of this thread) claim this:
Hi all..
Smps is stable with 1200W load.. for 45 minutes tested..
- Mos 52°C without fan
- Tranformer 55°C without fan
- Out diodes 61°C with fan (but small heatsink..)
On 1200w load i have 20V drop.. is due to transformer, now is winded with 5 x 0.4 wires.
I don't know if he measured the temperature of IGBT's body or the heatsink of them to get 52°c???!!!!
or something is wrong with mine????
I hope it was Tc. Badboy, what IGBT's did you end up with? And at what frequency does your SMPS operate?
Hello Jagd.Panther
in above measurements the smps frequency was on ~70Khz
but now I lower the frequency to 50Khz and now the IGBTs temperatures won't go higher than 60°c loaded with ~1400W for 10 minutes (I have to stop the test because of winding temperature)
My IGBTs are FGL40N120AND
Skin effect put litz.
I red somewhere that the safe frequency for 0.25mm wire(copper) is above 100Khz
I think my winding thickness is not enough???
Primary >> 22x0.25mm
secondary >> 32x0.25mm
The left one is Secondary homemade litz: outer diameter is about 2 mm
The right one is Primary homemade litz: outer diameter is about 1.5 mm
