first time build set trimpot to minimum, if you dont hear any sound at output, then slowly increasing the trimpot, it will be set duty cycle for this amp, too high will make mosfet overheat, too slow it will not oscillate. if there is anything or problem please ask me and make ur amp work and running nicely.
regards.
just for fun,
flyback for aux i just build, but it can drive tda2030 amp + 4 fan at the same time
really small flyback 6x3.2 cm pcb. plus regulator on board to probive 14.4 vdc stable with 4 12vdc fan load.
[video=youtube_share;dI9_G9qlhLI]http://youtu.be/dI9_G9qlhLI[/video]
Hello
greetings IRS3000D tested on 80 volt dc +/- FETS used FDA69N25 very detailed clear sound and
powerfull bass
warm regards
michelle
