What if I add a load of clothes iron, because I think the iron in it there is a heating element.
I have removed the inductor output, and i replace the c filter with 1uf, should i add secondary output snuber, ??? yes if you are willing to give the feedback option it sounds fun, I want to change the layout of you, without changing the value of the component, I use eagle pcb.itu if you really give feedback option, and with your permission. previous
Hi mr.silvio ,, thanks a lot, it means i have to slightly change pwm board, remove r470k, and change c16 with 100n value, also add r1k on pin 9 to ground. For opto circuit can i just use r on pin 2 opto to output min and some zener on pin 1 opto to plus output ,, i need to change the dead time resistor with value greater than 33ohm or maybe same mr.silvio, ???
For current transformer, if want to enlarge the current how about the secondary winding? The less the winding will the greater the current or multiply the winding for the greater the current in the OCP settings, ??
