Yes it means I have to use 8 diodes now ,,, i have to adjust the resistor which was 2.2k if it was before the zener, .but i should be able to power me if in view of the datasheet of the bias transistors there. To give them 50v power supply. I will try it. i will take all the resiko.jika it made a mistake, maybe i should learn to make class D.mungkin.saya ever read it power class d belong to norazmi.
You have to adjust resistor which was 47K and not 2.2K. I said put 33K instead for 50v if you want less voltage then use less like 27K or so. You can put preset resistor till you find correct value then put fixed resistor.
I did read posts from Norazmi and also from Stewin, I never built class D amp, They are very cheep to buy from E-bay or Aliexpress they are very powerful and small in size
https://www.aliexpress.com/item/IRS...805af34&transAbTest=ae803_2&priceBeautifyAB=0
