electro_luis
Thanks for your answer!
In summary - yes.hello when program saying me 5+5 secondry turns i have to wind 10 turns ???
Doesn't matter.and one other question i have to wind primary turns first or secondry?? please help
In summary - yes.
Doesn't matter.
Hi Dimonis
Thank you for a great effort .
Some small observations:
1. No help available.
2. Not intuitive placement. The output data is in the middle of two input data. Not a problem, just an observation
3. Addition of material type different from the list you have provided, does not seem to work. The core dimensions are accepted, as well as the core data like Ae and Ve, but the core material name is not being accepted in the list.
4. If the core chosen produces power less than the required output, then why is the option displayed as output? Or maybe a color change could be used to signify to the user that he is going the wrong way?
5. Is there any possibility of more topologies also? like Forward, Sepic, Cuk and so on
6. What about designing inductors also?
7. What about updates o the software?
8. What about systems where there are more than one switch in parallel?
All in all, an excellent initial effort. Needs polishing, thats all
Once again, Thank you very much.
Shiv
http://www.smps.com/Design/design.shtml
Hi Microsim
greetings any good 2kw smps schematic to share for ETD59 CORE using igbt or mosfets i am trying to learn the basics of smps building them
is the only way to learn hoping you can guide me
warm regards
michelle
Hi Michel
you can start with the Sg2525 chip, and GDT or IR2110
I will help you in your project
Don't worry ,Hi guys, Dimonis
Sorry for any misunderstanding being caused.
Isn't it a little bit offtopic ? I mean this thread is devoted to a design tool , and not to SMPS in all !i am trying to learn the basics of smps building them
can you share 1800 watts from etd49 schematic if its possible
It's up to you! It depends how convenient for you.finaly can you please tell me if i have to wind first primary or secondry turns
because software dont tell us
