Microsim, I used your formula, and I also think the freq must be in Hz and not in Khz !? Because I obtain too much turn for the primary
Vmin = 42VDC (I will be in push pull topology thus the result will be for 1/2 primary)
Freq = 70KHz
Bmax = 1200 Gauss (N87 material)
Ae = 3.68cm² (ETD59 core)
Thus we have 42*100000000/(4*70*1200*3.68) = 3396 turns.
With the frequency in Hertz the problem is solved : 42*100000000/(4*70000*1200*3.68) = 3.396 turn.
Ok so I calculated my transformer, need your opinion !
My need is a 48VDC -> 240VDC 3000W converter, but I want to use multiple transformers, primary in parallel and secondary in serie. I will try to obtain 3000W with 2 ETD59 transformer, 3C90 material, and full bridge topology.
With the formula Np = Vp x 10^8 / (4 B A f), I use Vp = 54V (max input voltage), B=1200G, A=3.68cm² (etd59), and f=100Khz.
I obtain Np = 54x10^8/(4x1200x3.68x100000) = 3.05 turns.
If I take 3 turns, Bmax become 54*10^8/(4x3x3.68x100000) = 1223G, I think it's good too.
And the input voltage will be at 54V for a very short period of time, the battery will go the the 48V nominal voltage very fast, thus Bmax will be 48*10^8/(4x3x3.68x100000) = 1087G.
For the secondary turn, with the 2 transformers secondary in series, I need 240+10% / 2 = 132V at the output of one transformer, thus with the minimal input value I obtain 132/42 = 3.14 ratio. Thus 3 primary turn x 3.14 = 9.42 turns = 10 turns for the secondary.
If I verify, 42V at the input (minimum input value) divided by 3 primary turns = 14, multiplied by 10 secondary turn = 140V, multiplied by 2 transformers = 280V. Thus normally it's OK, I will be able to regulate 240V with the duty cycle.
Now I need to see what I need for primary and secondary wire. The primary RMS current max for one transformer will be full power of this transformer with minimal input voltage, thus (3000W/2) / 42V = 36A on the primary (thus ~40A), and ~13A at the secondary.
For primary and secondary I plan to use copper foil, and wind the 3 turns primary first to have the minimum length of copper because of the 40A, and the 10 turns secondary on the primary.
But the question is, where to buy copper foil, I don't find it anywhere
Cyril
Thank you for your answer Microsim !
I look for the copper foil at RS or Farnell.
Just a question, with pull pull topology, the frequency transformer is the same frequency as the mosfets/controller, right ?
Hi there
Microsim ,
Thanks for transformer calculation methods.
I'm going to build a smps for giving +/-40V from 220V AC Line
Result based on your calculation Formula :
therefore , 16 Turns for pri. and 5+5 Turns for sec , but my question is what size of wire diameter ? (80v-8.75A Output it's means 700w rms )
can you help me for calculating wires diameter ?
"sorry for my English"
It looks to me you are using ETD59 @ 50KHz??? why?
ETD49 @ 80KHZ will give you 1200W nicely
please look at this sch for use ETD59 in 700w/50Khz SMPS !
http://www.img9.org/uploads/c32352d98af1712f7a19c993ceaed5df.jpg
I'm going to redesign my project !
Thanks Microsim
They use ETD59 Due low switching frequency. You can use ETD59 or ETD49
it depends on your application. I will provide you with any help u need
That looks cool!
have you checked the thread I told you about? it shows the complete SMPS.
You will need ETD49 with N27 Core material
All help is here
Tel us more about the sound of that mosfet amplifier please
